Is there a way to edit the Insert/Edit Component Dialog Box? I have a component that I have modified in symbol builder (added a 4th description line) but the only way to access the added attributes is through the properties.
Solved by rhesusminus. Go to Solution.
Try the button labeled "Show/Edit Miscellaneous". This will list all attributes NOT connected to any of the textboxes in the "Insert / Edit Component"-dialog.
THL
