AutoCAD Electrical General Discussion
Active Contributor
rkinsey
Message 1 of 5 (432 Views)
Quick Access Toolbar
432 Views, 4 Replies
12-11-2010 05:12 AM
My quick access toolbar disappears for no reason. I set it up, save my workspace, make sure that everything is locked. I close ACADE, open it at a later date and all my quick access icons are gone with the exception of the open and new page icons.
 Anyone else have this problem and is there anything that can be done? My thanks in advance.
Richard
Employee
KevinLi-Autodesk
Message 2 of 5 (306 Views)
Re: Quick Access Toolbar
03-01-2011 12:25 AM in reply to: rkinsey
Call command MENU in command line and reload acade.cuix to check if QAT comes back.
Kevin Li
Kevin-Hongyuan Li
Quality Assurance Team
Icemanau
Message 3 of 5 (291 Views)
03-01-2011 03:27 PM in reply to: rkinsey
Is that with a new dwg or is it without a dwg?
I've noticed that if all dwgs are closed, the only menu/tool bars that are available are the ones you mentioned.
Regards Brad
Icemanau (NNTP handle: Brad Coleman)
Employee
KevinLi-Autodesk
Message 4 of 5 (256 Views)
03-06-2011 09:53 PM in reply to: Icemanau
That is with a dwg.
Kevin Li
Kevin-Hongyuan Li
Active Contributor
rkinsey
Message 5 of 5 (245 Views)
03-07-2011 09:52 AM in reply to: rkinsey
All, this happens with an open drawing/project. The quick access tool bar as well as the ribbon (set the size and it gradually widens). My ribbon is docked on the right side of my screen w/autohide on. Just small things that make you go hummm
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Manufacturing Community
