My quick access toolbar disappears for no reason. I set it up, save my workspace, make sure that everything is locked. I close ACADE, open it at a later date and all my quick access icons are gone with the exception of the open and new page icons.
Anyone else have this problem and is there anything that can be done? My thanks in advance.
Richard
Call command MENU in command line and reload acade.cuix to check if QAT comes back.
Kevin Li
Is that with a new dwg or is it without a dwg?
I've noticed that if all dwgs are closed, the only menu/tool bars that are available are the ones you mentioned.
Regards Brad
Brad Coleman, Electrical Draftsman
That is with a dwg.
Kevin Li
All, this happens with an open drawing/project. The quick access tool bar as well as the ribbon (set the size and it gradually widens). My ribbon is docked on the right side of my screen w/autohide on. Just small things that make you go hummm
