i've created a part
i've created a footprint, inserted via the panel menu & browser, told it - it was a foot print
all works ok
if i run aepanelreport & include schematic BOM
I QTY = 2 ? should be = 1?????
(AB lanmps & nameplates works ok)
any ideas will be very helpful
Steve
Solved by Yeletah. Go to Solution.
Can you send us an example page? Put the schematic symbol and your footprint symbol on one page and post it here.
There should be a logical reason for this 🙂
THL
Hi
I was just preparing the drawings to send - thanks
Found it! the problem was with a transmitter & footprint - however i had the probe itself loaded with the same part number as the transmitter - hence i was getting a QTY= 2
A new question
I am running panel report with the full box ticked to get a full BOM list, by typing AEPANELREPORT into the command line
but why have a panel and a schematic BOM reporter?? why not just the one?
Thanks for your help
Steve
Hi Steve.
Some customers only draw the schematics, some customers draws only the panel drawings, while others draw both. So we need the flexibility in AcadE.
THL
