I am new to AutoCAD electrical. How do I insert a pushbutton, for example, that has more than one contact, and have it show more than one contact in my schematic? Currently I am going to "Icon Menu", then "push buttons", the selecting, again for example, "Push Button NO". It has one contact. What if I want two? Thanks guys/gals.
When you open up the Icon Menu, look a little further down and select one of the symbols with the "2+" notation. In the Component Tag entry of the Edit Component dialog box, give the symbol the same tag name as the original contact. Take note that you can select the component tag by pressing the Project or drawing buttons below the Component Tag field.
Thanks. Slightly off topic, but how do I globally change the text height of my components? I can edit each atribute individually and do it, but this is very tedious.
There is also a similar tool that will go through and adjust those settings in a library.
When you use this tool, it is best to set it up to run overnight as it will open every block in the library directory, make the changes and then save it.
Depending on how many blocks are in the library, this can take quite a few hours.
Regards Brad
Brad Coleman, Electrical Draftsman
