AutoCAD Electrical Forum
Publisher ecsCAD using in .NET
1 REPLY 1
innowell
808 Views, 1 Reply
We developed a function to manage ecsCAD projects in a DMS/EDM system. For this we have developed an addin to do the following:
- write a PDF using the ecscad publisher
- zip the ecscad project
both  document are then imported in the dms-system.
We use ecscad 2012
now the problem ist the publisher-function, if we use the following code to start the publisher-process:
                string projectName = "MyProject";
                ecsPublisherOLELib.Generation ep = new ecsPublisherOLELib.Generation();
                ep.Init();
                ep.Setting = "Einstellung PDF";
                ep.Format = 0;
                ep.Project = projectName;
                ep.OutputFile = projectName + ".pdf";
                ep.OutputFolder = "C:\\Temp\\";
                 //optional PDF Info
                string[] vInfo = new string[5];
                vInfo[0] = "Info 1";
                vInfo[1] = "Info 2";
                vInfo[2] = "Info 3";
                vInfo[3] = "Info 4";
                vInfo[4] = "Info 5";
                ep.DocumentInfo = vInfo;
                int r = ep.StartOutput;
- the publisher is starting
- I can see 1 of 4, 2 of 4 and so on
- at the end what I get is an empty PDF (sometimes there are some fragments in there) and after this the ecscad project is corrupted, even the dwg files are empty now
- the mdb seems to stay open (there is an ldb-file)
Does somebody has any idea what is going wrong here, any snippes how to do it...
Thank you for help
Regards
Daniel
1 REPLY 1
WoHo
in reply to: innowell
Daniel,
the following C# code snippet works:
[CommandMethod("ET_PDF_TEST", CommandFlags.Session)]
//session flag necessary for all commands invoked in AutoCAD ecscad
static public void _cmd_pdf_test()
            Autodesk.AutoCAD.Interop.AcadApplication acadApp = (Autodesk.AutoCAD.Interop.AcadApplication)System.Runtime.InteropServices.Marshal.GetActiveObject("AutoCAD.Application");
            acadApp.LoadArx("ecsPublisher.arx");
            acadApp.LoadArx("ecsPublisherOLE.arx");
            ecsPublisherOLELib.Generation ep = (ecsPublisherOLELib.Generation)acadApp.GetInterfaceObject("ecsPublisherOLE.Generation.182");  //182 correspond to ecsPublisher for AutoCAD ecscad 2012
            ep.Init();
            ep.Setting = "Einstellung PDF"; //the setting must be available in ecsPublisher
            ep.Format = 0;
            ep.Project = "M1N";
            ep.OutputFile = "M1N.pdf";
            //r == 0 ok or specific error code
You have also to set the references to the AutoCAD COM-API and the ecsPublisherOLE.arx (COM-API).
Regards
Wolfgang
”Boost
