AutoCAD Electrical Forum
Publish problem with autocad electrical 2012
4 REPLIES 4
Fred1986
931 Views, 4 Replies
I have a problem with autocad electrical 2012 Publish function. When I publish an error appear and my drawing did not plot.
When I try with my autocad electrical 2011 all work fine.
I think its a page setup problem but I'm not sure.
Someone had the same problem with Autocad electrical 2012 ?
Thank You !
Fred
Tags (3)
4 REPLIES 4
KevinLi-Autodesk
in reply to: Fred1986
Can you check if there is any difference of page setup between Autocad Electrical 2011 and 2012 ? how do you do the publish function ? right mouse click on the project, select Publish, then which option do you select ? you can select Plot Project option in this context menu to check the plot settings.
Kevin Li
Kevin-Hongyuan Li
Software Quality Assurance Engineer
Design, Lifecycle and Simulation Product Group
Direct: +86 21 2039 6025
Email: Hongyuan.Li@autodesk.com
NO. 130, Lane 91, E Shan Rd
Building 12, Floor 6,
Shanghai 200127, PRC
www.autodesk.com
Fred1986
We have a shared template with page setup include. Computer that have Electrical 2011 work fine but when we installed Electrical 2012 it didnt work. And I dont use your method to publish im using the Big A on the top left corner and after clicking on publish.
Fred
Fred1986
in reply to: KevinLi-Autodesk
Did you find something new about that problem ?
KevinLi-Autodesk
not yet, i have reported your problem to my colleagues for following up, will keep you updated for any findings.
Kevin Li
Kevin-Hongyuan Li
www.autodesk.com
”Boost
