AutoCAD Electrical Forum
Publish only prints one sheet
7 REPLIES 7
Message 1 of 8
cliffukele7866
4650 Views, 7 Replies
I am having problems with the multisheet publish function.  Publishcollate is set to (1) yet when I try to publish multiple sheets to pdf only one sheet gets published.  What am I missing??
7 REPLIES 7
Message 2 of 8
cbenner
in reply to: cliffukele7866
Message 3 of 8
cukele
in reply to: cbenner
I am using the batch plot on the ribbon
Message 4 of 8
s.wile
in reply to: cukele
Does the Publish dialog show a list of layouts or only one? Can you post an image of this dialog right before your ready to publish?
Stan Wile
http://myacade.blogspot.com/
IMAGINiT Technologies
Message 5 of 8
Icemanau
in reply to: cukele
Is the PDF of the last sheet published or the first. If it's the last sheet, then something may be wrong with your PDF driver/settings causing all the sheets to overwrite the previous sheet rather than adding the new sheet to the existing file.
Regards Brad
Brad Coleman, Electrical Draftsman
Message 6 of 8
EBBEB
Hi cliffukele7866
Try to look into this video maybe this helps you.
http://autodesk.typepad.com/systemsdesign/2012/03/how-to-create-one-pdf-file-that-contains-the-whole...
Have a nice day
Ebbe
EBU
Message 7 of 8
cukele
in reply to: s.wile
All layouts are visible and an image can be reviewed before printing to pdf.
Message 8 of 8
AS to do with the "publishcollate" option. Type the function and set it to "0".
I had the same issue and this was the solution
regards
”Boost
