I am having problems with the multisheet publish function. Publishcollate is set to (1) yet when I try to publish multiple sheets to pdf only one sheet gets published. What am I missing??
What publish command are you using? The batch plot button above the ribbon menu? Or right click on the project and select publish there?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Does the Publish dialog show a list of layouts or only one? Can you post an image of this dialog right before your ready to publish?
Is the PDF of the last sheet published or the first. If it's the last sheet, then something may be wrong with your PDF driver/settings causing all the sheets to overwrite the previous sheet rather than adding the new sheet to the existing file.
Regards Brad
Brad Coleman, Electrical Draftsman
Hi cliffukele7866
Try to look into this video maybe this helps you.
Have a nice day
Ebbe
AS to do with the "publishcollate" option. Type the function and set it to "0".
I had the same issue and this was the solution
regards
