AutoCAD Electrical General Discussion
New Member
cliffukele7866
Message 1 of 7 (481 Views)
Publish only prints one sheet
481 Views, 6 Replies
03-19-2013 09:07 AM
I am having problems with the multisheet publish function.  Publishcollate is set to (1) yet when I try to publish multiple sheets to pdf only one sheet gets published.  What am I missing??
cbenner
Message 2 of 7 (455 Views)
Re: Publish only prints one sheet
03-20-2013 09:55 AM in reply to: cliffukele7866
What publish command are you using?  The batch plot button above the ribbon menu?  Or right click on the project and select publish there?
ChrisB
Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
http://cbennertipstricks.blogspot.com/
Member
cukele
Message 3 of 7 (449 Views)
03-20-2013 11:57 AM in reply to: cbenner
I am using the batch plot on the ribbon
Distinguished Contributor
s.wile
Message 4 of 7 (406 Views)
03-26-2013 07:24 AM in reply to: cukele
Does the Publish dialog show a list of layouts or only one? Can you post an image of this dialog right before your ready to publish?
Stan Wile
http://myacade.blogspot.com/
IMAGINiT Technologies
Icemanau
Message 5 of 7 (402 Views)
03-26-2013 03:22 PM in reply to: cukele
Is the PDF of the last sheet published or the first. If it's the last sheet, then something may be wrong with your PDF driver/settings causing all the sheets to overwrite the previous sheet rather than adding the new sheet to the existing file.
Regards Brad
Icemanau (NNTP handle: Brad Coleman)
Employee
EBBEB
Message 6 of 7 (395 Views)
03-27-2013 01:00 AM in reply to: cliffukele7866
Hi cliffukele7866
Try to look into this video maybe this helps you.
http://autodesk.typepad.com/systemsdesign/2012/03/how-to-create-one-pdf-file-that-contains-the-whole...
Have a nice day
Ebbe
EBU
Member
cukele
Message 7 of 7 (383 Views)
03-27-2013 07:06 AM in reply to: s.wile
All layouts are visible and an image can be reviewed before printing to pdf.
Manufacturing Community
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
