AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Publish in Background do not work after ACADE 2013 Service Pack 1 installation.
4 REPLIES 4
hav
1130 Views, 4 Replies
To plot to PDF I use function Publish to DWF, and then change format from DWF to PDF.
After SP1 installation on ACADE 2013 Publish in Backround function stopped worked. I wait 30 minutes and icon in right down side is still show Publish Job in Progress. Project has only 15 sheets. I tried it with different projects but result is the same.
Publishing directly (not in Background) works good.
Only Me have this problem?
Anton.
4 REPLIES 4
RobinShou-Autodesk
in reply to: hav
I have checked this issue in my ACE2013 SP1 in Win7 64 OS, everything works well with no problem, please check the video.
Please let me know if there are any special settings you have done for the plotting.
Here is the video: http://screencast.com/t/hMsVCD5mOD
Robin Shou
Quality Assurance
AutoCAD Electrical
Autodesk, Inc.
hav
in reply to: RobinShou-Autodesk
I do not know what happend, but now Publish in Background working fine.
Thank you for support.
Anton
RobinShou-Autodesk
in reply to: hav
Thanks for the update. Please let us know if you still have any issue when using the AutoCAD Electrical 2013.
Robin Shou
Quality Assurance
AutoCAD Electrical
Autodesk, Inc.
Backgroup plotting does not work on my machine Smiley Sad.  I am using Windows 7 32 bit machine with AutoCAD Electrical 2013 SP1.  Are there issues with 32 bit machines?  If I changed my OS to 64 bit, will it fix the issue?
Thanks!
”Boost
