AutoCAD Electrical General Discussion
hav
Active Member
hav
Message 1 of 5 (858 Views)
Publish in Background do not work after ACADE 2013 Service Pack 1 installation.
858 Views, 4 Replies
09-29-2012 12:45 AM
To plot to PDF I use function Publish to DWF, and then change format from DWF to PDF.
After SP1 installation on ACADE 2013 Publish in Backround function stopped worked. I wait 30 minutes and icon in right down side is still show Publish Job in Progress. Project has only 15 sheets. I tried it with different projects but result is the same.
Publishing directly (not in Background) works good.
Only Me have this problem?
Anton.
Employee
RobinShou-Autodesk
Message 2 of 5 (815 Views)
Re: Publish in Background do not work after ACADE 2013 Service Pack 1 installati
10-03-2012 02:01 AM in reply to: hav
I have checked this issue in my ACE2013 SP1 in Win7 64 OS, everything works well with no problem, please check the video.
Please let me know if there are any special settings you have done for the plotting.
Here is the video: http://screencast.com/t/hMsVCD5mOD
Robin Shou
Quality Assurance
AutoCAD Electrical
hav
Active Member
hav
Message 3 of 5 (808 Views)
10-03-2012 03:35 AM in reply to: RobinShou-Autodesk
I do not know what happend, but now Publish in Background working fine.
Thank you for support.
Anton
Employee
RobinShou-Autodesk
Message 4 of 5 (803 Views)
10-03-2012 03:53 AM in reply to: hav
Thanks for the update. Please let us know if you still have any issue when using the AutoCAD Electrical 2013.
Robin Shou
Quality Assurance
AutoCAD Electrical
Active Contributor
linnea.lukic
Message 5 of 5 (667 Views)
12-13-2012 06:24 AM in reply to: RobinShou-Autodesk
Backgroup plotting does not work on my machine :smileysad:.  I am using Windows 7 32 bit machine with AutoCAD Electrical 2013 SP1.  Are there issues with 32 bit machines?  If I changed my OS to 64 bit, will it fix the issue?
Thanks!
Manufacturing Community
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
