AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Publish Drawing Set
1 REPLY 1
JMARSHALL1249
295 Views, 1 Reply
Publish Drawing Set
Is it possible to change the default output location when publishing to a PDF, such that it puts the PDF in the root directory of the Project, rather than to user\documents
1 REPLY 1
lionSG
in reply to: JMARSHALL1249
Have you tried going to the options dialog, and under the Plot and Publish tab:
Set your default path for the Plot to file operations to see if it works.
”Boost
