I know how to change the name of the layers ACADE uses (SYMS, DESC, WIRENO, etc). But is there a way to control the other properties, like color and plot style?
I know I can pre-define the layers in a template, but I'd rather just allow them to go on being created on the fly. So far, renaming the layers via AEPROPERTIES appears to be the only thing we can change. Is there a way to edit the other properties too?
Jim
Also, I'm not finding anything on panel layers at all (PTAG, PBAL, PITEM, etc). Is there even a way to rename these layers?
ALL layers can be modified through the standard 'Layer Properties Manager' from ACAD. This is part of ACADE as well.
Select it from your ribbon or use Layer on the command line.
The only thing that makes an ACADE layer special is the layer name and the ability to designate certain layers as wire layers.
It is possible to change the names BUT you also have to change the names in each dwgs properties.
In the Drawing Format tab click the Define button in the Layers section.
I recommended that you do not change the name of any of the ACADE layers but all other parameters should be fine to change.
Regards Brad
Brad Coleman, Electrical Draftsman
I'm not sure but it may be that layers created on the fly take their settings from Layer 0.
Regards Brad
