I suggest copying the default_cat.mdb to a file named complete_cat.mdb. This will be a backup of the original. Make the changes to the default_cat.mdb. This is the file AcadE looks for by default. If you remove lots of vendor data with Access, I recommend running the repair and compress utility in Access to speed up the database search time. Now in your project properties go to the Project Settings tab and set up a secondary catalog lookup by clicking on the button labeled Other in the catalog lookup section. Point to the complete_cat.mdb as your secondary catalog lookup. You can trim the default_cat.mdb down to preferred vendors but you have the complete_cat.mdb available when needed by clicking Other during a lookup.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in
AutoCAD Electrical training and implementation support
Phone and
Web-based Support Plans AvailablePhone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please
Accept as Solution if I helped you.
Likes are also much appreciated.
