Hi there!
I was wondering if someone could point me to the right direction regarding this matter.
I often use this tool to change attribute sizes project wide such as TAGS, Description text etc.
I have however not figured out how to change attributes on source/destination arrows and some other things.
Is this described somewhere in the help or anywere?
Hope to get some hints....
Regards, Gary
Hi Gary,
The Source / Desitnation arrows use "XREF" as the Main Text.
So you would have to apply the change to Xref attributes as well.
What other symbols are you trying to edit and are having trouble with?
James Alger
Hi James,
If I select to change the parent and slave cross reference text this only applies to the cross reference text and not the description attribute nor the wire number attribute. Is this possible throug this tool or do I need to make my own style?
As shown on the attached image, the cross reference text is decreased from 2.5 to 2.0 size but the description and wirenumber reference is not affected.
Thanks again for your support.
Regards, Gary
