AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Project wide symbol attribute visibility toggle
8 REPLIES 8
Message 1 of 9
ccad2509
980 Views, 8 Replies
What I'm after is a solution to the following
I would like to search through a completed project and set a default attribute in a symbol to a defined state I,e all desc3 attributes on or off
we can do it with the IEC tags using ICE tag mode update  I just want to do the same for all the standard attributes in a symbol
any ideas on how to achieve this
8 REPLIES 8
Message 2 of 9
rhesusminus
in reply to: ccad2509
As far as I know there is no standard tool within AutoCAD Electrical that will do this for you.
little something to make it a LITTLE faster manually, is to use the AEHIDEATTRIB command.
This wil make you select a bunch of inserted blocks in a drawing, and then give you a list of attributes available in these blocks. Then you can just select what attributes to hide, and press OK.
Trond Hasse Lie
AutoCAD Electrical and EPLAN expert
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
Message 3 of 9
jdenny
That AEHIDEATTRIB work very nicely. So.......is there an AEUNHIDEATTRIB command? (i tried that one:))
Jeff Denny
Sr. Engineering Manager
Harris Corporation
Melbourne, Florida
Message 4 of 9
rhesusminus
Not in front of the computer right noe, but try AESHOWATTRIB ?
(While I continue to enjoy Sherlock S01E03 🙂 )
Trond Hasse Lie
Ctrl Alt El
Message 5 of 9
jdenny
in reply to: rhesusminus
Perfect. That does make things much easier.
Thanks.
Jeff Denny
Harris Corporation
Melbourne, Florida
Message 6 of 9
ccad2509
The solution wont work for me as i have projects over 400 pages in size and i want to switch of certain symbol attributes so we then can then issue as biult drawings to our clients needless to say information in fields switched of is details we would prefer our end user not to know
Message 7 of 9
rhesusminus
I guess the best solution will be for you to contact your AcadE reseller, and ask them if they can create a small add-in (AutoLISP, VBA or .NET) for AutoCAD, that can be run via command-line, like this:
Command: MYSHOWHIDEATTRIB
Block/Attribute names: BLOCKNAME;DESC1;DESC2,DESC3
Found 3 references of BLOCKNAME in drawing
Turned on DESC1
Truned off DESC2,DESC3
Then, this command could be used in a script and all drawings could be processed via Project-Wide Utilities.
Trond Hasse Lie
Ctrl Alt El
Message 8 of 9
philhep
Where's Nate when you need him?
Message 9 of 9
ccad2509
Yes I was hoping someone would say if you take the  "IEC tag mode update script"
file and make the following changes then you will be able to force the other symbol attributes to be visible or invisible
”Boost
