I am slammed and I went in to test something for another suer. When I try to go to the settings on any Project it does not open the dialog box. I right click and hit settings and it just sets and thinks, then it has the active foot print in the command line...
Any Ideas why this is happening?
Andrew,
what version of AutoCAD Electrical are you using? It sounds like there might be a missing file but that is just a guess. If you follow these steps and post the log file it might provide some clues.
In AutoCAD Electrical type these commands at the command line-
1. LOGFILEON
2. AEONLISPDEBUG
3. wd_help_proj_settings
4. AEOFFLISPDEBUG
5. LOGFILEOFF
6. LOGFILENAME
Then post the log file that is named in the last step and I can take a look at it.
