Sorry. I should have been more specific. DEMO01 is one of the drawings in
the sample project loaded with AcadE. It might only be loaded if you select
the JIC standard. There are different sample projects depending on the
standard selected at installation.
If you select Drawing Properties (Acade2007 or Drawing Configuration AcadE
2006, attached picture shows AcadE 2007 dialog) you select Wire Numbers,
Sequential and enter the starting number. The starting number for each
drawing, and the drawing order in the project, defines a range.
Say you have a project with 3 drawings in this order, DWG1, DWG2, and DWG3.
Say you enter 1 as the starting number on DWG1, 101 on DWG2, and 201 on
DWG3. This defines the range for DWG1 as 1-100, for DWG2 101 to 200, and
DWG3 starts at 201. Further, say that when wire numbering is added to DWG1
it actually needs 101 numbers, so uses numbers 1-101. Even though DWG2 is
supposed to start at 101 it actually will start at 102.
Again, all this is only relevant if your drawings are set up to use
Sequential wire numbering.
Pat Murnen
wrote in message news:5151950@discussion.autodesk.com...
What is DEMO01? a drawing? a code? a value I should set in the sequential
number box?
how does AE know to use this range?
I'm confused 😞
