AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Project Navigation
1 REPLY 1
sniktun
239 Views, 1 Reply
Project Navigation
Hi guy's
Is there a command I can run to navigate through a project? so lets say I have 80 pages in a project and need to open page 63. Is there a command I can run to jump me straight to page 63? otherwise I have to open a bunch of drawings to figure out which one is which.
James
1 REPLY 1
rhesusminus
in reply to: sniktun
Well, using the project manager you can open whatever sheet you want.
On the bottom half of the project manager you can also toggle between showing the details of the sheet or a preview (thumnail) of the sheet.
If you can't see the project manager tool palette, go to the Project-tab in the ribbon, and press the button called Manager.
Also, the contents of the project manager can be modified to show more information that just the filename of the sheet. See the button named Drawing Display List Configuration among the topmost buttons in the project manager.
Trond Hasse Lie
AutoCAD Electrical and EPLAN expert
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
”Boost
