AutoCAD Electrical General Discussion
Distinguished Contributor
iomaxx
Message 1 of 6 (411 Views)
Project Manager box locked in leftside of screen
411 Views, 5 Replies
10-09-2012 05:18 PM
I haven't encountered this before. The project manager box is locked on the left of the screen, and there is no option to move it, only to close it (see pic). I went into the CUI and tried editing it under the pallettes section, but nothing changed. any thoughts?
Did you lock the position of your toolbars in the problem workspace.
Look at the bottom left of the acade window. In the status box there should be a padlock.
If the padlock is closed, you may have locked the positions. Right click and select the docked menu bars, then select unlocked.
Now try and move the menu bar and see if that works. If all else fails, try unlocking ALL the items.
Regards Brad
iomaxx
Message 2 of 6 (408 Views)
Re: Project Manager box locked in leftside of screen
10-09-2012 05:51 PM in reply to: iomaxx
another note, i changed workspaces to the autocad electrical default, and the box is able to be moved again. for some reason, the 'acade & 2d drafting & annotation' workspace doesn't allow the project manager box to move in any way. Is that by design, anyone know?
testsubject
Message 3 of 6 (394 Views)
10-10-2012 07:31 AM in reply to: iomaxx
Did you try to Left Click and Drag on the Title Bar for that window? That is how I always move it.
Bob Hanrahan
Ace User since 1998
iomaxx
Message 4 of 6 (392 Views)
10-10-2012 07:35 AM in reply to: testsubject
yes, if i try moving it, the mouse pointer just turns to a red circle with a line through it.
testsubject
Message 5 of 6 (388 Views)
10-10-2012 07:43 AM in reply to: iomaxx
That was all I had. Maybe someone from Autodesk can respond.
Bob Hanrahan
Ace User since 1998
Icemanau
Message 6 of 6 (366 Views)
10-10-2012 07:21 PM in reply to: testsubject
Regards Brad
Icemanau (NNTP handle: Brad Coleman)
Manufacturing Community
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
