AutoCAD Electrical General Discussion
Distinguished Contributor
2 Kudos
Post 1 of 6
Project Manager box locked in leftside of screen
431 Views, 5 Replies
10-09-2012 05:18 PM
I haven't encountered this before. The project manager box is locked on the left of the screen, and there is no option to move it, only to close it (see pic). I went into the CUI and tried editing it under the pallettes section, but nothing changed. any thoughts?
Did you lock the position of your toolbars in the problem workspace.
Look at the bottom left of the acade window. In the status box there should be a padlock.
If the padlock is closed, you may have locked the positions. Right click and select the docked menu bars, then select unlocked.
Now try and move the menu bar and see if that works. If all else fails, try unlocking ALL the items.
Regards Brad
2 Kudos
Post 2 of 6
Re: Project Manager box locked in leftside of screen
10-09-2012 05:51 PM in reply to: iomaxx
another note, i changed workspaces to the autocad electrical default, and the box is able to be moved again. for some reason, the 'acade & 2d drafting & annotation' workspace doesn't allow the project manager box to move in any way. Is that by design, anyone know?
76 Kudos
Post 3 of 6
10-10-2012 07:31 AM in reply to: iomaxx
Did you try to Left Click and Drag on the Title Bar for that window? That is how I always move it.
Bob Hanrahan
Ace User since 1998
2 Kudos
Post 4 of 6
10-10-2012 07:35 AM in reply to: testsubject
yes, if i try moving it, the mouse pointer just turns to a red circle with a line through it.
76 Kudos
Post 5 of 6
10-10-2012 07:43 AM in reply to: iomaxx
That was all I had. Maybe someone from Autodesk can respond.
Bob Hanrahan
Ace User since 1998
193 Kudos
Post 6 of 6
10-10-2012 07:21 PM in reply to: testsubject
Regards Brad
Icemanau (NNTP handle: Brad Coleman)
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Manufacturing Community
