AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Project default parameters
2 REPLIES 2
l.cellini
362 Views, 2 Replies
I would know the procedure for to change the project parameters with my chooses.
Pratically I would open a new project with my parameters, now I need always to change.
Thanks at all for help.
Luigi
2 REPLIES 2
vladop
in reply to: l.cellini
Create a project with your settings.
When you want to create new project in Create New Project dialog box find Copy Settings from Project File field and browse to project with your settings (see attachment).
Here is explanation for this field:
Specifies the project settings. You can select a previously defined project setting and apply it to your new project definition file. Click Browse to select a previously defined project definition file to copy over and apply settings to the new project being created. If blank, copies the settings from the active project.
l.cellini
in reply to: vladop
very good
thanks
”Boost
