According to the project file list, the file should be one of the files that
the Project Database Service (PDS) is to monitor and look for changes. It
would then use the data in the drawing and update the scratch database. The
message means that the file could not be found and is therefore being
ignored.
If the file is relevant to your project, then you should make sure it is
available. If it is not important, you may want to consider removing it from
the WPD file (Project ) to avoid unnecessary processing, as PDS is pretty
persistent in trying to locate the file and will continue to check every now
and then to see if it has suddenly returned (such as a temporary network
interruption).
Lee
wrote in message news:5335044@discussion.autodesk.com...
So this error will not affect anything and should be ignored?
Thanks.
