I am constantly getting the following
error with ACADE 2007
Has anybody else seen this or know of a way to resolve it
Is this an ACADE or a Vault problem
Sometimes it is with the active Database sometimes not.
Everything else seems to be working fine.
ERROR MESSAGE
Database SQL Error:
'T:\CHROBAK\677646 SN3\677646-010.DWG'
Row #: 0 Source: "Microsoft JET Database Engine"
Description: "The INSERT INTO statement contains the following unknown field name: 'WD_M_HDL'. Make sure you have typed the name correctly, and try the operation again."
Help File: "(null)" Help Context: 5003018
GUID: {0C733A63-2A1C-11CE-ADE5-00AA0044773D}
SQLState: 3127, NativeError: -527762915
INSERT INTO [FILETIME] ([DWGIX], [STAMP], [DWGNAME], [SH], [SHDWGNAM], [IEC_P], [IEC_I], [IEC_L], [ALTXREFFMT], [WDLEV], [PNL_X], [PNL_Y], [PNL_Z], [WD_M_HDL]) VALUES ('10', '20060726.134849', 'T:/CHROBAK/677646 SN3/677646-010.DWG', '10', '677646', NULL, NULL, NULL, '%S-%N', NULL, NULL, NULL, NULL, 'h=30A')
This is in the log for every drawing in the project.
Thanks for any help
Joe
