- Set or update the value of variable GBL_wd_prj_ixlst
But how do I update, replace a list and than run the command ? Does somebody have an example ?
Update from MDB 2 project List, looks like I have to edit the data base and than run this command to update the project ?
And :
- (nth 4 GBL_wd_prj_ixlst) = list of DWGNAM values (the %D value)
this one is always empty, ok I can get it from nth2 :
- (nth 2 GBL_wd_prj_ixlst) = list of full drawing name and paths
when i remove the path and extention.
But is this (nth 4) not the name of the DWG ?
Solved by Wheelie22. Go to Solution.
My mistake
I have to edit the WD_M file to change the SHEET and SHEETDWGNAME attributes and then use the C:WD_TB_PROCESS_ONE command to update them.
To finish it refresh the PM manualy, because there is no lisp command for that.
For now this only works on the active drawing, so I have to open all drawings in the project (or sub folder in the PM) to make the changes.
