Have you tried to rebuild the project database?
Run the AEREBUILDDB command, and see if that changes anything.
If you've still got the error, it would be nice to have a look at the actual drawings.
OK, first of all, check your XREF display settings as well as the settings for the referencing system itself.
You may have inadverdently set it to display unused child contacts or the referencing may be out of whack.
Second - As rhesusminus said, do a full rebuild of the of the project database.
Run the cross reference command on one of the problem components to check if that fixed the problem.
If that failed to fix the problem, save everything and exit out of ACADE. do a search for the <PROJECT NAME>.mdb file and delete it.
When you restart ACADE, the project database will be rebuilt from the dwgs.
If that fails, use the SURF command on the problem components and go to each of the contacts.
Delete/Rename or leave as is depending on what the Surf command brings ups.
Let us know if all that fails.
Regards Brad
Brad Coleman, Electrical Draftsman
