iomaxx,
I looked over the messages and I noticed that in the bad alternate profile,
you are missing these two messages:
Loading Electrical modules...
Loader application completed.
What this might mean is that the loader module (the .Net module that loads
the rest of the Electrical specific modules) is not being loaded. I don't
recall for sure, but I think there was a change between 2007 and 2009 such
that a .Net module is being used as the loader instead of an ARX module. I
think it is the aceloader.dll module now. Anyway, this module is loaded
through a registry entry. I have 2010 installed and I see it on my computer
under
"HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD\R18.0\ACAD-8007:409\Applications\Acade"
since you are using 2009, yours will be slightly different. Check to make
sure that this module is getting loaded. Hope this helps.
Mike
"iomaxx" wrote in message news:6257872@discussion.autodesk.com...
we are installing acade 09 finally, and i'm having some issues with the
shortcut we had created during the deployment creation. we set up this
alternate profile with centrally located paths for templates, etc. (as we
did for acade 07). this time however, when i open the shortcut that the
normal deployment created, it opens up fine (and i can modify the paths
afterwards), but when i click on the additional shortcut i created, which
points to the alternate profile, it doesn't load WD_ARX_FORMAT_PATH for some
reason. i thought if i tried matching the support paths between the
alternate profile and the standard ACADE profile, that it would clear this
up, but it hasn't. here is the command line from the startup when ran from
each shortcut (the good, ACADE profile shortcut, and the bad alternate
profile shortcut)
...any thoughts would be greatly appreciated...
the good profile:
Customization file loaded successfully. Customization Group: ELECTRICAL
Customization file loaded successfully. Customization Group: ACAD
Customization file loaded successfully. Customization Group: IMPRESSION
Customization file loaded successfully. Customization Group: CONTENTSEARCH
Customization file loaded successfully. Customization Group: EXPRESS
Customization file loaded successfully. Customization Group: MECHWORKS
Regenerating model.
AutoCAD Express Tools Copyright © 2002-2004 Autodesk, Inc.
AutoCAD menu utilities loaded.
AutoCAD Electrical menu utilities loaded.
DBWorks menu utilities loaded.
Initializing VBA System...
Command: COMMANDLINE
the bad profile:
Regenerating model.
AutoCAD Electrical menu utilities ; error: no function definition:
WD_ARX_FORMAT_PATH
