AutoCAD Electrical General Discussion
New Member
0 Kudos
Post 1 of 2
Problems using MOVE COMPONENT, COPY COMPONENT, SCOOT, etc.
399 Views, 1 Replies
08-06-2012 01:09 PM
Since upgrading to AutoCAD Electrical 2012 (from 2008), I have been having problems when I try to MOVE, COPY, etc., componets.  When I select the component, and then the command, I pick up the component, but as soon as I move the mouse, it immediately drops it (usually above and to the right, outside my title block).  If I use the normal AutoCAD MOVE command, to move other objects, it works perfectly.  Any ideas would be appreciated.
New Member
0 Kudos
Post 2 of 2
Re: Problems using MOVE COMPONENT, COPY COMPONENT, etc. (Problem Resolved)
08-07-2012 09:02 AM in reply to: dmyer
The problem has been resolved
I am running AutoCAD 2012 under Windows XP Pro, using Parallels Desktop 7.0.15104, on a MacMini.  After making several attempts at mouse configuration changes, and downgrading Parallels to version 7.0.15054, to no avail, I removed the mouse driver loaded by Parallels version 7.0,15104 (in Windows).  When I rebooted, the original Logitech mouse driver reloaded and the issues were resolved.
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Manufacturing Community
