IM HAVING PROBLEM WITH CATALOGUE SEARCH
5 WORKER USES THE SAME DATABASE
2 OF THEM
CAN'T FIND SOME ITEM'S WITH THE "PART CATALOGUE WINDOW"
( WHEN SEARCHING WITH "SEARCHING CATALOGUE DB, ITEM FOUND, BUT CAN'T BE SELECTED
ALL OTHER WORKERS USING THE SAME DB WITH NO PROBLEM
I CHECKED ALREADY PROPERTIES SETTING, ALL OK
ALSO "PART CATALOGUE" WINDOW INDICATE THE CORRECT PATH OF DB FILE
ALSO DID A FULL UN-INSTALL AND REINSTALL, BUT THIS HELPED ONLY FOR A WEEK ,AND THEN PROBLEM REPEAT AGAIN
AND CAN'T FIND THE PROBLEM
Did you check their catalog database search sequence?
Make sure they dont have the default_cat.mdb in their user subdirectory or the ACE support file search path is correctly setup. If they are using the wd.env file, check the WD_CAT path.
Try relocate or rename the default_cat.mdb or the project-specific.mdb that you are currently using and see if they still can open the catalog lookup file?
