AutoCAD Electrical Forum
Problem with PDB blocks (DB)
1 REPLY 1
croland
325 Views, 1 Reply
I am currently using AE 2012 and having problem with the power distribuion block electrical symbol.  I can not get AE to label wires on bothside of a pole.  It only labels one wire and the other one is left unlabeled.  The wire being use is marked to be labeled and there is no wire numbers on a hidde layer either.
1 REPLY 1
Icemanau
in reply to: croland
It sounds like you have a block that is passing the wire number through.
Try inserting a wire number copy after the distribution block. If the block is passing the wire number through, your copy will reflect that.
Regards Brad
Brad Coleman, Electrical Draftsman
”Boost
