Any one can help me how to Slove this problem.
When I am trying to insert Circuit by using circuit builder concept , I find the connection missing between control circuit and power circuit. And when the same concept is inserted in different drawing sheet, it is working fine.The drawing properties for both the drawing sheets are same. How can this anomalous behaviour of circuit be addressed. I need this circuit working correctly any number of times it is inserted and in any sheet.
As you can see in the below image there is no connection between MA-2(L3) and FU2(3).
Now the same consept is called in different sheet, here the connection is fine
But In Master Circuit
