Hello.
I have repaired, reinstaled and always the same problems.
I have some issues that Mr. Autodesk could revise. (I know it is not the proper way and time, but...)
The connector command has a problem with the list button
When you insert a connector it works fine, but when you have to edit it (the connector list) the autocad went TILT.
1-Insert Connector
2-Edit Connector
3-Push List button
4-Tilt
5-Ctrl-Alt-Supr and restart all again.
The only way it doesn't crash is when you edit the list from the attribute button (right clik).
Other crash is when I use the next/previous drawing project arrows. - FATAL ERROR
Another fatal error is when I double click the file in the project manager. (I made a copy of the Iec and inserted new files)
I have audited the dwt and no problems with it.
At the end the question. How could I uninstall the program (complete). It let folder in the system that not erase.
Autocad Electrical 2013 x64 in a XP x64
Everthing legal - the acade is a Trial (Much better but unstable)
We use Acade 2010
Sorry for my english
Arq. Ernesto Fraga
Montevideo - Uruguay
