style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Does this happen when you try and insert the
circuit on to a blank new drawing? If so, if you send the project file,
one drawing, and one circuit to me at
href="mailto:pat.murnen@autodesk.com">pat.murnen@autodesk.com I can
take a look and see if I can tell what is happening
Pat Murnen
<MoparMark> wrote in messageOk,
href="news:6039120@discussion.autodesk.com">news:6039120@discussion.autodesk.com...
I tried creating a new project and copying the settings from my circuits, but
it still does the same. (I added my circuits into a project and did a settings
compare to copy drawing settings to project, then used this project to copy
settings from when i created the new project). I am
perplexed
"Pat Murnen" <
href="mailto:nospam_pat.murnen@autodesk.com">nospam_pat.murnen@autodesk.com>
wrote in message
href="news:6039372@discussion.autodesk.com">news:6039372@discussion.autodesk.com...
Pat Murnen
but it still does the same. (I added my circuits into a project and did a
settings compare to copy drawing settings to project, then used this project
to copy settings from when i created the new project). I am
perplexed
<MoparMark> wrote in messageDoug,
href="news:6041217@discussion.autodesk.com">news:6041217@discussion.autodesk.com...
Thanks for the input. That is what I assumed the problem to be as I am in
Australia and am using the AS library, however the AS components insert into
my drawings at the correct scale and it is only my circuits that seem to be
enlarged. I have tried varying the scales of the drawing, project and circuit,
but the problem remains. Pat, It inserts into a blank drawing at the large
size, however the text sizes don't scale like when inserted into my project. I
am sending a circuit and one of my temp projects I used to test my scaling
problems. The drawing in the project has the circuit already inserted from the
insert component menu, and you should find that by copying and pasting the
circuit there is no scaling issue. Thank you both for your help,
Mark
