AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Problem layer and file extension dwg
0 REPLIES 0
Message 1 of 1
185 Views, 0 Replies
When I work on my portfolio, I am on the current layer 0.
And when I insert the wire, sometimes I end up with the current layer as the layer "wires" and with the thickness of the line "0.00" instead of "BYLAYER". which meant that when I print, I have not the right thickness for the j'utile "monochrome.ctb".
And sometimes the file extension dwg is capitalized.
Does anyone has seen this?
And why I do that?
Thank you for your answers
0 REPLIES 0
”Boost
