Whey you select the "Insert Wire" tool, you can hold your mouse over a
device and hit the "s" key followed by the space bar and AutoCAD Electrical
will place a large green "X" on each of the wire connection points so you
can easily see the exact point where the wire will attach itself.
Give it a try and let me know if that helps.
Scott
wrote in message news:4859847@discussion.autodesk.com...
Sometimes when I connect wire at a component it gets attached to some other
point on component & not at the desired location?
