AutoCAD Electrical Forum
problem in connecting wire
2 REPLIES 2
242 Views, 2 Replies
Sometimes when I connect wire at a component it gets attached to some other point on component & not at the desired location?
2 REPLIES 2
Whey you select the "Insert Wire" tool, you can hold your mouse over a
device and hit the "s" key followed by the space bar and AutoCAD Electrical
will place a large green "X" on each of the wire connection points so you
can easily see the exact point where the wire will attach itself.
Give it a try and let me know if that helps.
Scott
wrote in message news:4859847@discussion.autodesk.com...
dougmcalexander
Also be careful that your object snap settings are not creating a problem. The green "X" feature that Scott speaks of (a feature they put in to humor me a long time ago) is also very helpful. But often the problem you describe can be caused by broad object snap settings
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in AutoCAD Electrical training and implementation support
Phone and Web-based Support Plans Available
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please Accept as Solution if I helped you. Likes are also much appreciated.
”Boost
