I am haivng a problem formatting the row height in tables. When I set the text height the spacing defaults to a number that is much to large. The row height is displaying as approximately 8 times higher than the actual text. This results in the table not fitting on the layout. Any help would be greatly appreciated! Thank you!
Hi!
If I understood you issue correctly, there are some space (like you pushed Enter button) under and below text. So you could delete its manually.
I don't see how to do that. I am inserting the table from the report generator. I would have to spend a lot of time manually deleting space and resizing the table if that is the only way.
You may want to generate a BOM on a dwg first even if it doesn't conform to what you would like to see. Within that dwg go to your pull down menu -> FORMAT-> Table Style...
This will open a dialog box and look for ACE_TABLE_1 ,select it and click modify. This opens another dialog box where you can format your table.
Once you have it looking the way you want, save it as current.
Tip: you can use Design Center to insert this table style into your standard dwg template for easier reference or modification later on..
Hope this helps!
Ok thanks for that, but it still didn't change anything. I attached a screenshot to possibly help out. I changed the margines to 1/8" and then set it to current like you suggested and nothing changed. I re-ran the generator and nothing changed. Am I still doing something wrong?
Hmm... Maybe look at a few possible issues.
Any changes?
