One thing you might want to check is make sure the Plot Style Table that you
are using has the 'Lineweight' option set to 'Use Object lineweight'.
You might try running the plot command and selecting 'monochrome' as your
Plot Style Table and see if the lineweight plots correctly then. I think
the defect for the monochrome Plot Style Table is to have Lineweight set to
'Use Object lineweight'. If that works, then you should just have to change
the Lineweight setting of the Plot Style Table you are using to 'Use Object
lineweight' by using the 'Plot Style Manager'
Steve
wrote in message news:4857482@discussion.autodesk.com...
Hi there,
I am very very new to ACE actually just 2 weeks into it.
During my first drawings, I have to set the main wires thicker than the
other wires so I changed the "thickness" to 0.80mm from "By Layer."
My problem is when I print the drawing from ACE all the wires have the same
thickness however when I print it to PDF, it shows the main wires thicker
than the other wires as expected.
Why cant ACE print the different thickness? Is there is any other way to
print from ACE?
Other problem occurred right when I print to PDF. The relays (only relays,
other components, like switches, are OK) relay names, and their comments
were printed very thick. All I could see in the PDF was just thick coloured
dots.
So either from ACE or PDF I couldn't get the desired result in printing.
Please help me to get a good printing. Thank you.
