AutoCAD Electrical General Discussion
Active Member
hetzelm
Message 1 of 8 (396 Views)
Printing Issue
396 Views, 7 Replies
06-18-2012 09:25 AM
I am running ACADE 2013 on a W7 32bit computer.
I can batch plot to a pdf but can not print or batch plot to a printer.
If I try to print individual sheets (CtrlP) one I hit print ACADE stops responding and I have to use Task Manager to shut it down.
If i try to batch plot it "starts" ploting in the tool bar by quickly stop and I get a caution symbol but no error message.
Can anyone help me with this?
pendean
Message 2 of 8 (387 Views)
Re: Printing Issue
06-19-2012 04:48 AM in reply to: hetzelm
plotting to what?
Using what driver? Do you also use a PC3 file?
Is your pagesetup set correctly (PLOT or PUBLISH) for the one device?
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Active Member
hetzelm
Message 3 of 8 (384 Views)
Re: Printing Issue
06-19-2012 04:59 AM in reply to: hetzelm
I am trying to print on my HP5200 printer. I have tried using the PCL6 and PCL5e drivers.
Neither seem to work.
It looks like my pagesetup is correct.
I am not sure what a PC3 file is.
pendean
Message 4 of 8 (376 Views)
Re: Printing Issue
06-19-2012 10:19 AM in reply to: hetzelm
Did you install HP's Universal Driver for the HP5200, or are they from the disk that came with the printer?
Active Member
hetzelm
Message 5 of 8 (374 Views)
Re: Printing Issue
06-19-2012 10:52 AM in reply to: pendean
Its a network printer. I installed it with the add printer function. I did not use a disk.
Active Contributor
p_enneking
Message 6 of 8 (350 Views)
Re: Printing Issue
07-05-2012 10:53 AM in reply to: hetzelm
I have a user running AcadE 2012 on a windows 7, 64 bit machine.  He is trying to print monochrome ladder logic prints on our HP 5200.  No matter what we change, it prints grayscale every time.  He mentioned that he only ever noticed it as a problem in AcadE 2012 (doesn't remember the problem being there in AcadE 2011.)
Thoughts?
testsubject
Message 7 of 8 (343 Views)
Re: Printing Issue
07-05-2012 12:43 PM in reply to: p_enneking
Under Page Setup for plotting, there is a section called Plot style table (pen assignments). This should be set to monochrome.ctb for monochrome printing.
Bob Hanrahan
Ace User since 1998
Active Member
hetzelm
Message 8 of 8 (309 Views)
Re: Printing Issue
08-24-2012 05:36 AM in reply to: hetzelm
I now have 3 W7 computers that have this same issue. Two 32-bit and one 64-bit machne.
HP5200dtn networked printer
I cannot print or print preview anything out of ACADE 2013 it crashes and I have to use Task Manager to close it out.
Batch Plot to a printer does not work either.
I have to batch plot to a pdf then print the pdf so I know the print drivers are correct. I can print using any other program on my PC except ACADE.
Can anyone help?
Manufacturing Community
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
