I recently upgraded to ACE2009 ant am having trouble with the previous/next buttons not working. The following it a paste from the text window after opening a project and trying to switch drawings with the buttons. It looks as if it dosent recognize the command. Also if I try to run a BOM report there is no information.
Can anyone figure out how to fix this?
Opening an AutoCAD 2000 format file.
Regenerating model.
Press ENTER to continue:
AutoCAD Express Tools Copyright © 2002-2004 Autodesk, Inc.
AutoCAD menu utilities loaded.
AutoCAD Electrical menu utilities loaded.
Autodesk DWG. This file is a TrustedDWG last saved by an Autodesk application
or Autodesk licensed application.
Command: (COMMAND "_.SCRIPT" "C:/DOCUME~1/YERKOV~1/LOCALS~1/Temp/ace2D1.scr")
_.SCRIPT
Enter script file name <>:
Command: nil
Command: WD_OPEN_DWG
Unknown command "WD_OPEN_DWG". Press F1 for help.>
