AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
preplot and post plot command script files
4 REPLIES 4
ADD_123
926 Views, 4 Replies
Why do Pre plot Command script file  and Post plot command script files are run before and after plotting, respectively. I suppose running these files is optional.
What are the commands in the default preplot.scr and postplot.scr files?
4 REPLIES 4
rhesusminus
in reply to: ADD_123
There aren't any default pre-/postplot.scr files supplied with AcadE.
There are several cases where you'd like to process the the drawings before and after the plot command.
Maybe you would like to have the text "PRELIMINARY" inserted diagonally across the drawing and insert the plot-date into the titlle block before it's sent to the printer?
And... after the plot is done... If' you'd like to SAVE the plotdate inserted into the titleblock, you'll have to delete the "PRELIMINARY" text first, before saving the drawing.
There are many more cases where you can use this functionality.
Trond Hasse Lie
AutoCAD Electrical and EPLAN expert
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
ADD_123
Thanks for the reply. But one more doubt;
If there are no default preplot and post plot command script files available, then, what does Preplot.scr and Postplot.scr mean(path of both these files is given in the edit boxes of the Optional for each Drawing area) which are mentioned in the Batch Plotting Options and Orders dialog box.
rhesusminus
They are just examples of filenames you can use. Nothing more.
Trond Hasse Lie
Ctrl Alt El
ADD_123
Thanks once again. Still one more question? How do script files are created? I could only understand that there are commands in these files and its format is .scr. Does anyone need to know specific kind of scripting to create them?
”Boost
