These description values are saved in the project's .wdp file. You could
carefully edit the .wdp file (maintaining its structure) and quickly assign
description values to one or more drawings. Here is some information from
the Help on the .wdp file structure. Read the entire topic to understand the
entire structure. I have only copied the protion related to the list of
drawings and the information that can be added for each drawing. (It is a
little hard to tell since the text runs together but those are 3 equal signs
in front of the descriptions.)
Overview of the project file format (TOPIC name)
Project drawing list
All remaining entries give the relative path (relative to the location
of the project's .wdp file itself) to each drawing that is part of the
project. The drawing name is given first. Then, if special assignments or
descriptions are defined for the drawing, this information follows the
drawing name in subsequent lines. Each line is prefixed with a code. If
special "sec/sub" groupings are defined, then a drawing's "sec" is preceded
by a "=" entry and "sub" by a "==" entry. If one to three lines of
description are defined, each is preceded by a "===" entry. If a drawing is
marked "Ref only", it is preceded by a "====REF" entry.
Pat Murnen
wrote in message news:5990394@discussion.autodesk.com...
There is no way to get som "default descriptions" into these fields. The
drop down list will only consist of what's already written in the
description fields for the other drawings in the project.
THL
