AutoCAD Electrical General Discussion
matthewjohnston4386
Message 11 of 12 (115 Views)
Re: Power Bus using Terminal Blocks with 4 entry points
08-05-2011 08:11 AM in reply to: Icemanau
Okay, I see that now! I didn't even know this tool existed.  I think that with this combined with placing the block in a smart fashion will be a good solution.
Thank you so much!
Matthew Johnston
Matthew Johnston
Sr. Controls Scientist
Corning Inc.
Distinguished Contributor
iomaxx
Message 12 of 12 (74 Views)
01-31-2013 08:17 AM in reply to: matthewjohnston4386
Just curious if you finalized how you did things. I use the same 4connection terminals, and I have them set up as 4 level terminals (should i set them as 2level though?), and when working on a schematic drawing, I just have to be aware of the need to place a terminal every 4th connection on an I/O bus. I haven't been able to figure out how to make use of the wire connection sequence tool though.
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Manufacturing Community
