AutoCAD Electrical General Discussion
Member
0 Kudos
Post 1 of 3
Populate Panel from schematic list, not marking existing
225 Views, 2 Replies
11-21-2005 12:43 PM
I've been using the populate panel from schematic list feature in autocad. I just ran a project resequence/retag on a set of drawings. After the run, i opened populate panel from schematic list again. I reloaded the program, and selected marked existing. However, the program will not mark some inserted footprints even though I see that they were inserted earlier from populate panel from schematic list. I've re-built the project database, reloaded populate panel, and still see the same problem. Does anyone have any suggestions?
~Mark
0 Kudos
Post 2 of 3
Re: Populate Panel from schematic list, not marking existing
12-14-2011 03:00 PM in reply to: sparckis
I am having the problem noted above.  I am taking the following steps:
  1. "Schematic List" in Panel.
  2. Press "Reload"
  3. Press "Mark Existing"
  4. Components which exist on the panel are not being marked as existing.
:smileymad:
0 Kudos
Post 3 of 3
12-14-2011 03:59 PM in reply to: sparckis
If found the problem.  My footprint block had an "FPT" (Terminal Footprint) attribute.  The footprint was identified as a terminal rather than a component.
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Manufacturing Community
