It looks like something is confusing the auto-routing. Just start the wire
at TB4A, come down, click, then go right and click on the left quadrant of
D. In other words, start the wire command and manually route the wire.
wrote in message news:5878935@discussion.autodesk.com...
Thanks for the speedy reply. Forgive my ability to construct my question in
a way to ask what I want. I'm transitioning from MicroStation to AutoCad
Elec.
The problem is with 1wire 2 connection points.
See attachment for visual.
Connecting wire from TB4A/7 to pin D.
Why does it loop around pin D?
Can I stop that from happening while inserting the wire and not having to
fix it afterwards?
Thanks!
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in
AutoCAD Electrical training and implementation support
Phone and
Web-based Support Plans AvailablePhone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please
Accept as Solution if I helped you.
Likes are also much appreciated.
