AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Plotting question
4 REPLIES 4
mpedersen134
450 Views, 4 Replies
Plotting question
I have a drawing file with no XREF attached.  This drawing does not have a drawing border in model or paper space but a border is printed.  Can anybody tell me where this reference border may be coming from?  No hidden/off/locked layers to speak of.  I have the file attached.
4 REPLIES 4
jalger
in reply to: mpedersen134
Hi Mpedersen134,
I just looked at your drawing.
I think its coming from your line which is going around the Drawing.
When you print are you printing extents or a window?
James
James Alger
(I'm on several hundred posts as "algerj")
Work:
Dell Precision 5530 (Xeon E 2176M)
1tb SSD, 64GB RAM
Nvidia Quadro P2000, Win10
mpedersen134
in reply to: jalger
Hello, Jalger.
I'm printing Extents.  I'm referring to a company produced title block/border and not just a rectangular box.  I've attached a copy of a print in .pdf format.  You will see the included border.
Another weird thing happening is, when I do zoom extents, it doesnt' show the drawing's actual extents.  Instead it zooms into part of the drawing.
Thank you for your help.
jalger
Hi Mpedersen134,
The title block is in the layout (its hidden behind your Viewport).
If you Change the Page Size to Ansi E (34x 44) you can see its behind it.
Not sure how it got there. (I'm guessing you reused a page from another project)
I hope this helps,
James
James Alger
Work:
1tb SSD, 64GB RAM
mpedersen134
in reply to: jalger
Thank you, James.  I can't belive that was the issue.  I appreciate your time.
”Boost
