I have a drawing file with no XREF attached. This drawing does not have a drawing border in model or paper space but a border is printed. Can anybody tell me where this reference border may be coming from? No hidden/off/locked layers to speak of. I have the file attached.
Solved by jalger. Go to Solution.
Hi Mpedersen134,
I just looked at your drawing.
I think its coming from your line which is going around the Drawing.
When you print are you printing extents or a window?
James
Hello, Jalger.
I'm printing Extents. I'm referring to a company produced title block/border and not just a rectangular box. I've attached a copy of a print in .pdf format. You will see the included border.
Another weird thing happening is, when I do zoom extents, it doesnt' show the drawing's actual extents. Instead it zooms into part of the drawing.
Thank you for your help.
Hi Mpedersen134,
The title block is in the layout (its hidden behind your Viewport).
If you Change the Page Size to Ansi E (34x 44) you can see its behind it.
Not sure how it got there. (I'm guessing you reused a page from another project)
I hope this helps,
James
Thank you, James. I can't belive that was the issue. I appreciate your time.
