AutoCAD Electrical Forum
PLOTDATE / PLOTDATE update
13 REPLIES 13
Message 1 of 14
adrien.levasseur
1501 Views, 13 Replies
I have a TitleBlock "ACADE_TITLE", using WD_TB attribute to uptdate my automatic fields : TIME = PLOTTIME ; DATE = PLOTDATE etc...
All are working but PLOTDATE / TIME.
When updating, ACE doesn't care TIME and DATE, even though he cares the other unchanged attributes.
I also tried *project*.wdt, but i am not sure ACE read it when update.
See appendix to see my title block.
Could you help me please ? Thanks
13 REPLIES 13
Message 2 of 14
Did you try using Plot Project and then see if this value changed?
It appears this is only updated when the Plot Project is run:
http://wikihelp.autodesk.com/AutoCAD_Electrical/enu/2011/Help/User's_Guide/115Project-WideTools/1399...
At least that is how I read this.
Hope this helps.
Bob Hanrahan
Ace User since 1998
If this answered your question, please click on "Accept Solution"
Message 3 of 14
When i plot my project ??
Smiley Frustrated
I only tried plotting one draw by one draw....
Thanks Bob, now this is working
Message 4 of 14
To go further :
Could i use a plotdate with DDMMYY format ? There is no proposition for this format in ACE (wiki)help
Message 5 of 14
That I don't know. Maybe Pat or Kevin have the answer to that one.
Bob Hanrahan
Ace User since 1998
Message 6 of 14
btackes
in reply to: testsubject
PLOTDATEMMDDYY
current date (MM:DD:YY format)
PLOTDATEYYMMDD
current date (YY:MM:DD format)
PLOTDATEYYYYMMDD
current date (YYYY:MM:DD format)
This is for 2012 not sure about earlier versions.
Message 7 of 14
adrien.levasseur
in reply to: btackes
I have same PLOT YMD combinations as you do with my 2009 version.
Actually, this is not really an important issue.
I'd rather use YYYYMMDD
Spoiler
I just wonder why the format MMDDYY exists, this is non-sense
Thanks for your help
Message 8 of 14
I'd just like to add that you can always use a FIELD as an attribute text. Plotdate/time is a field that AutoCAD (Electrical also) updates automatically when a drawing is plotted. No matter hoe one plots the drawing (manually, Plot Project etc.)
THL
Trond Hasse Lie
AutoCAD Electrical and EPLAN expert
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
Message 9 of 14
You are reaviling an interesting point.
I remember using LISP expression in some of my title block's fields (have a search "tbnp.lsp" for next and previous sheet on this forum, this was brought by dougmcalexander)...
In the " _Field" command, i found the many date formats, where highlighted "DateTracé" means "PlottingDate". Then with dd/MM/YYYY format, i find the expression :
%<\AcVar PlotDate \f "dd/MM/yyyy">%.
So i will soon try in my WD_TB :
DATE = %<\AcVar PlotDate \f "dd/MM/yyyy">%
Message 10 of 14
You don't have to put that in the WD_TB attribute or WDT-file. Just insert the field in the drawing template (dwt-file), and it will be a part of all new drawings.
THL
Trond Hasse Lie
Ctrl Alt El
Message 11 of 14
sonny3g
in reply to: rhesusminus
I did insert the field in my .dwt file.  It inserts correctly in my drawings and will print the plotdate and time correctly whether plotted in a project batch plot or individually THE FIRST TIME ONLY.  After that, it might but usually does not print the time only the date.  If I re-insert the field manually, it prints correctly once then the next time only the date.
Any ideas what might be causing that?
Thanks.
Scott
Scott G. Sawdy
scott.sawdy@bluecoyotecad.com
Message 12 of 14
Icemanau
in reply to: sonny3g
Check your field update setting. If it's set to update only on saving, that could be whats causing the problem...
regards Brad
Brad Coleman, Electrical Draftsman
Message 13 of 14
sonny3g
in reply to: Icemanau
My field update setting was: on open, on save, on plot, on regen and on etransmit.  It is now just on open, save and plot.  Unfortunately, I have to manually replace the field in the attribute before plotting every time if I want the plot time included in the plotdate.
Scott
Scott G. Sawdy
Message 14 of 14
rhesusminus
I'm not able to get AutoCAD to "forget" the field setting here. Could you post a drawing with a field here?
THL
Trond Hasse Lie
Ctrl Alt El
”Boost
