AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
PLC Symbol Default Text Locations
13 REPLIES 13
Message 1 of 14
dianamichelle33
1081 Views, 13 Replies
How do I edit the default location of the text on a PLC symbol that has been supplied with AutoCAD Electrical?
13 REPLIES 13
Message 2 of 14
caddude1
in reply to: dianamichelle33
Do you mean a predrawn symbol (as in a relay coil) or something generated by a script (a PLC module)?
Mark Behrens
Autodesk Expert Elite
Controls Designer/CAD Manager
38 year AutoCAD user | AutoCAD Electrical user
Message 3 of 14
dianamichelle33
in reply to: caddude1
I mean the PLC module generated by a script, I know it's made up of a bunch of symbols - is there a way to tell which symbols are being used?
Message 4 of 14
ccad2509
Go Schematic tab>Other tools> Pulldown and select PLC Database File Editor
It will Launch the database which the script controls when building a PLC Symbol
BE Careful Read The Help Files Before you Starting Modifying Symbols Etc
Message 5 of 14
caddude1
Is this for a specific module or all modules of a specific type (inputs or outputs)?
Mark Behrens
Message 6 of 14
dianamichelle33
Eventually it's going to be for all modules, but at the moment I am trying to edit the AB#1756-IB16
Message 7 of 14
caddude1
Something important to keep in mind, the format between modules as they were entered initially should not be assumed to be consistent. A/b should be pretty consistent, just cover your bases.
Mark Behrens
Message 8 of 14
jalger
Hi Diana,
If i understand correctly you want to change the location of the text in the file that drives the PLC Editor.
Its a fun undertaking, about 81 files ( 40 horizontal ,41 Vertical files) per PLC Style.
I would actually Copy one of the existing styles that you like and edit that one as PLC Style 5 - 9.
The files are located in:
C:\Users\Public\Documents\Autodesk\Acade 2015\Libs\NFPA
(My example is the 2015, NFPA library, if you are using a different one (like JIC, or IEC, then select that path)
you are looking for files that have Hp# and Vp# (Where the # is the style).
(DO NOT CHANGE THE NAMES EXCEPT FOR THE NUMBER!, otherwise the selections will not work properly)
The H Symbols are for Horizontal wires.
The V Symbols are for Vertical Wires.
Here are some of the names fro the sample files that you are looking for:
Hp1-a-dl.dwg (Horizontal, Style 1, Top Input )
Hp2d-awo.dwg (Horizontal, Style 2, Normally Open Contact Output)
Vp1-a-dl.dwg (Vertical, Style 1, Top Input )
vp2d-awo.dwg (Vertical, Style 2, Normally Open Contact Output)
Again as stated, make a copy of the style you want to edit and change all of the Numbers to one of the unused styles (5 - 9)
All you need to do is Move the text in the symbol, you could make other change in the file as well (change the size of the box, or of the text).
I hope this helps,
James Alger
James Alger
(I'm on several hundred posts as "algerj")
Work:
Dell Precision 5530 (Xeon E 2176M)
1tb SSD, 64GB RAM
Nvidia Quadro P2000, Win10
Message 9 of 14
dianamichelle33
in reply to: jalger
Thanks everyone, useful information.
If I don't want to edit all of these symbols at once, is there a way to tell what symbols are used in the script for a specific PLC so I can sort of edit them as I go?
Message 10 of 14
caddude1
in reply to: jalger
Very well said. I would make sure that the blocks are backed up in a separate directory prior to any changes being done. My initial reply that you would be correcting the base blocks that the script inputs did not note that? (my error). The practice of having a backup copy of the supporting blocks AutoCAD has built in is a good thing just to be sure, as it is not uncommon for files to become corrupted.
Mark Behrens
Message 11 of 14
jalger
Hi Diana,
Which card (s) are you trying to Edit? (I can find out the dwg from the PLC Database editor, if its one of the existing ones)
Is it a horizontal or Vertical Wire bus configuration?
If you can share that with me, I'll let you know which ones to edit.
James Alger
James Alger
Work:
1tb SSD, 64GB RAM
Message 12 of 14
dianamichelle33
in reply to: jalger
At the moment I'm trying to edit
AB#1756-IB16 (horizontal) - this one is most important, others can wait
AB#1756-OW16I (horizontal)
AB#1756-IF6I (vertical)
AB#1756-OF4 (vertical)
AB#1756-IR6I (vertical)
Message 13 of 14
jalger
Hi Diana,
Here are the symbols you need to Edit (Grouped in the Cards).
I used PLC Style 1 for the File names.
Module Info Input I/O Point Wire Left  (HP1WA-DL.dwg) (so Horizontal, Style 1, Top, input with wire going left)
Input I/O Point Wire Left (HP1WA-D.dwg)
Terminal Point Wire Right (HP1-W.dwg)
Module Info Output I/O Point Wire Left and Right (HP1DWAWL.dwg)
Output I/O Address Point Wire Left and Right (HP1WDAW.dwg)
Terminal Point Wire Left and Right (HP1W-W.dwg)
Module Info Terminal Point Wire Left (VP1W--L.dwg)
Input I/O Point Wire Left (VP1WA-D.dwg)
Terminal Point Wire Left (VP1W--.dwg)
Module Info Terminal Point Wire Right (VP1-WL.dwg)
Terminal Point Wire Right (VP1-W.dwg)
Output I/O Point Wire Right (VP1D-AW.dwg)
Module Info Input I/O Point Wire Left (VP1WA-DL.dwg)
Terminal Point Wire Left  (VP1W--.dwg)* This is a repeat Don't do it twice 🙂
Input I/O Point Wire Left (VP1WA-D.dwg)* This is a repeat Don't do it twice 🙂
So look for:
HP1WA-DL.dwg
HP1WA-D.dwg
HP1-W.dwg
HP1DWAWL.dwg
HP1WDAW.dwg
HP1W-W.dwg
VP1W--L.dwg
VP1WA-D.dwg
VP1W--.dwg
VP1-WL.dwg
VP1-W.dwg
VP1D-AW.dwg
VP1WA-DL.dwg
I hope this helps,
James Alger
James Alger
Work:
1tb SSD, 64GB RAM
Message 14 of 14
dianamichelle33
in reply to: jalger
Thanks James!
”Boost
